Did they test the injector return flow? If its too high at any injector it won't build rail pressure enough to fire the motor. There are some troubleshooting tips here under the heading
ENGINE WILL NOT START/HARD TO START
http://dodgeram.info/tsb/2006/14-003-06.htm
