Hello all. I have an '89 D150 with 318 and stock front suspension. I have new suspension parts to put in (upper and lower ball joints, inner and outer tie rod ends, & strut rod bushings) and have been thinking about doing the springs and shocks at the same time. Truck is at stock ride height with no plans to lower it. Wheel and tire combo is upgraded to a 265/35/22. What I want to do is control the front end bounce when I hit humps at speed. Is there a truck that I can pull springs from at the junk yard that will help? Say D250 or a crew crab that will have heavier/stiffer springs. Is there an application that I can look at for stiffer shocks? An HD version from the parts stores? A high $ part like bilsteins etc is out of the question. I've always had good luck with stock replacements from the parts store but I've never looked for anything stiffer.
Thanks in advance
roe
