Hi all,
I was trying to follow the instructions from the dodgetravcos site and set timing 0n my 440 to 38 BTDC at 2600-2800 rpm.
I just cant get there.
I have a 440 with a Comp Cams 280H cam and a Street Demon carb (the newer Thermoquad/Quadrajet hybrid style)
When I turn the idle set screw all the way down I only get 2350 rpm.
Car seems to run fine, has good power.
What am I doing wrong? Is something limiting the idle mixture screw at idle in Park?
can I just set 38BTDC at 2350 RPM.
Any help or advice would be greatly appreciated.
Vic
