I have my 2 step on the brake pedal, how would i wire it to my port a tree.
I was going to put two 1/4" jacks in the dash, one to the
tran-brake and one for the practice tree. Then, I could
just plug my delay box into either one, using the button
in the car and the delay box.
You could do the same thing, except you only need a jack
that alternates between your 2-step and practice tree.
.......unless you have a momentary switch in place of
the brake light switch that closes the circuit with the
button UP. Then you'll have to settle for the foot switch
they sell or put a hand button in the car.
