That's a pretty involved process. There's pics around the web showing the location/size/depth of the holes that need drilled in the back side of the flywheel to balance it for a 360, but I'd just buy the right flywheel. But it's not a bad idea to locate those pics so you can see if the one you're buying is properly balanced.
