Originally Posted By booger
Originally Posted By ruderunner
Sounds like an ABS problem. Pull the fuse for the abs pump (light will come on) and see if it still happens.
Most likely a failing wheel speed sensor.
If he has multiple sensors giving false readings he may very well have no brakes.
Originally Posted By SteveS
With an ABS capable scanner, you should be able to see which wheel sensor thinks a wheel is locked up. It won't throw a code, because it thinks it is doing its job.
Originally Posted By Silver70
once I pulled the fuse, stops perfectly fine. I have a bad wheel sensor that never once threw a code.
To the OP, pull the abs fuse under the hood and try it.
You were all right, I pulled the fuse and went for a drive without it happening once. Normally it happens before I get to the end of the spur I live on (about 100 feet). Now to get the codes pulled and the thing fixed.
Thanks to everybody for the help, you saved me some $$$ for sure wave
I'm surprised but I guess it's possible.
Please reply and let us know what you find if/when it has a scan tool on it. I would ask whoever looks at it to take it for a ride with the scan tool to monitor what happens rather than just deleting codes.
'71 Duster
'72 Challenger
'17 Ram 1500
