So do tell what would a set for a Predator deal run one
I don't have any info on the Predator heads so I wouldn't have any way to design a set of valve covers for them. Indy should have the CNC data on the heads so they should be able to design a set of valve covers without much work. If I had the CAD file for the valve cover rail then it only takes an hour or so to design the cover.
I could get you that, if your interested in taking on the project.....
