header flanges are the same but they ports on the heads are raised about 3/8 of an inch so not in the stock location.
The intake valve is moved and you need special rocker arms that are .800 offset.
The 440-1 flow about 80cfm out of the box better than those heads and are capable out flowing them big time with fully ported.
They are in a different league, big step up from Procomp/Eddies.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
