When I get the car moving from a standstill in drive and under normal acceleration, it shifts very quickly from first to second gear and there is kind of a down surge that makes you lurch forward. Of all the Mopars I have had with 727's this is the only one that has done this. The shift from second to third is normal. Maybe something else is causing this but my first thought was the valve body.
