Originally Posted By Adam71Charger
Green horn input here, but if his quench is good, doesnt dynamic compression ratio have more to do with detonation than static?
Quench is not good, dynamic CR still high because cam is sort of small for the static compression ratio, Stock iron heads and spark plug location at edge of chamber doesn't help either.
If it were me, I would zero deck the block for quench and toss some RPM heads on it, but I think he wants to use the iron heads? It sounds like he has some time and $$$ into them?
