I own 1968 dodge charger with factory bendix disc brakes. I had my pair of front disc brake calipers repaired with staainless sleeve inserts installed. I had new pistons and new seals installed. I find using dot 5 silicone brake fluid the calipers leak around the seals. I can tell when I find the stopping the car is getting slower because of silicone fluid on the rotors. Anyone out there have similar problem ? Any one got idea how to fix ? should I replace silicone brake fluid with plain brake fluid? Bob H. 708 687 1187
