well you already know the stock manifolds will kill a lot of power. all i can add is i run 11.25cr with J heads and speed pro flat tops, the heads have been milled a lot 59cc. 195 cranking psi. runs good on 93 with very cold plugs. a lot of torque and nice pop out of the exhaust!
