I took the speedo gear housing and gear out of the BB 727 Im working on. The gear is black plastic with a metal shaft the slides into the housing. The black plastick gear has a 29 code on it, the metal housing that it slides into has a series of numbers stamped on it: 39-45 32-38 26-3
What do the numbers tell me on each piece?
