I had a aluminum intake and a set of cast aluminum rocker covers powder coated once back in the ealry 1990s, never again That darn powder coating is a great insulator, but it KEEPS the heat in instead of keeping the heat out. Heat rises so when it is hot in the motor and aluminum coducts heat very well and then the powder coating keeps the aluminum sealed up the parts get so hot you can't harddly touch them
