I have temp and oil pressure gauges started pegging all the way over when key is on, thought I had a bad limiter until I found that when I turn the park lights on those gauges return to off position. This started after the airgrabber switch was taken out for repair. Anyone heard of this problem where light switch kills the gauges? I tried grounding the cluster with a jumper but no difference. Thanks
