So after I took care of the broken snap rings and the governor solenoid kit for the P1757 code, the Durango drove great. Friday I noticed that when I came to a stop, it didn't downshift to 1st. You can manually shift into 1st or bump it to neutral for a second and all is well again. This is kind of intermittent- it might do it one time or it might do it 3or 4 times in a row. No codes... work
Suggestions?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
