Originally Posted By Seth_Jones
Any problems to look out for? Getting ready to install both sides on my 69 bee. Trunk extensions too
Check the actual side marker fit, and recessed side marker stamping to see if it's correctly placed and sized on the qtr, and check the end cap fit on the qtr, easier to rework these section before install
The AMD trunk extension might leave something to be desired as far as fit/function, I've found the Goodmark B body trunk extensions a better fit with less work when used with AMD rear qtrs
