The guy that puts my motors together locally is a SB chebby guy. I was at his shop yesterday BSing and he has a R5/P7 in there to be gone through. One question that has come up is what is the aluminum tube looking thing that is under the 60mm needle bearing cam tunnel? From the rear of the block it looks like a tube but from the front looking into the tunnel it looks like a solid spool.
