67SAT the wood has too much give when you hit it, your loosing 1/2 your "wackem" power! Cleaning the crud out of the receivers (both ends of the bar) helps a lot, and a little penetrating oil also helps, but sometimes you just have to show them (the T bars) who is going to win. Gene
