Originally Posted By G_bob
Originally Posted By racerAL
both intakes are standard port as are my heads.
That's interesting, because the MP online cantalog shows the P4876337, P4876128 & P4876129 intakes as all being max wedge ports. With the 337 being for 4150 carb, max wedge, and stock heads. The 129 being for 4500 carb, max wedge stage VI heads. And the 128 being for "four barrel carb", max wedge stage VI heads.
Not sure is that "four barrel carb" on the 128 means it will handle both 4150 and 4500.
I'm looking for a lower profile 4500 alternative to the super Victor on the Eddie super victor max wedge heads.
You might be able to rework the plenum with a 4500 bolt pattern and then it would be a lower profile alternative to the Super Victor. When you add a 4150 to 4500 adapter on top of the 337 it gets about as tall as a Super Victor.
