Originally Posted By 5280Dart
An option would be to take your drums to a machine shop and have them drill a second bolt pattern with hole diameters to facilitate the use of the studs you are able to get. They could press the studs in and you would be good to go. Just a thought.
Can't do that. These are 2 piece, the hub is separate from the drum. They'd both need to be re-drilled. I guess that is an option.
