Make sure the temp is above 60 or it wont cross link harden correctly even if you heat it up later. 2k products go thru a chemical reaction and have to be above that temp to work correctly.
I agree make sure the temp is right so it cures right before top coating it.
Skip the wax grease remover what is it Dx330 in PPG, just use laqure thinner to wipe it down since you will proberly have some spots that got dirty when you touching it and leaning on it were blasting the engine bay.
i believe its dx101
