No pics(in DC) but on my Stratus it is attached on the door bar with rivets and a piece of stainless. The top is attached with two seat belt buckles. Simple and easy and came that way from RJ. It drops completely out of the way for ingress and egress. Which is a plus since there is a very small space in get in and out through.
On the Cuda we have a tube on the bottom of the net that is bolted into tabs on the door bar, tube adapters in tube ends to allow for bolts. The top is on a tube that slides through another tube at the back and a buckle up front. That way it drops completely out of the way for getting n and out.
