Got the new line on. Now my brake pedal isn`t like it really should be. It seems to be a little spongy. I bled all four calipers to where no air was coming out. I was reading online that air can get trapped in ABS unit and a scan tool is needed to release it. Is there any way to doing it without gong to the dealer? BTW, I did double check for leaks and I had good flow to all the calipers.
