Need some help confirming my theory here before I dig into this...
4wd truck with cv axles and sealed hub units. Has what sounds like a bearing howl in the front end. The howl stays on right-hand turns but disappears on left-hand turns. Which bearing is bad?
(I see this as a "bearing issue" as opposed to a "truck issue" so I put it here.)
Cheeto
It's not perfect.
It's not correct.
It's not yours!
