Originally Posted By stumpy
Originally Posted By Frankenduster
The procedure about the longest lining going on the rear: Isn't this a matter for REAR brakes only due to the fact that the parking brake is attached to the rear shoe?
Applies to the front also.
Yep, what he said! Long lining on the rear most shoe, short lining on the forward shoe, each wheel, all 4 corners the same set up. Always! Gene
