Thanks for the info!
I'd installed the Moog offset uca bushings last rebuild in early '90s and never could get a decent alignment. Can you use the Hotchkis UCA with tall spindles? I pulled a disc brake setup from a '75 Fury many years ago and was considering installing it finally.
