Buying a new set of bearings isn't the biggest problem in the world. I just finished a new short block and we didn't use either the rod bearings or the main bearings that came in the stroker kit. Experienced engine builders typically keep several sets of bearings on hand and they'll split sets to get the correct clearance. It is more of a craft than an assembly line.
