NV3500 Specifications and gear ratios
•Single shift rail
•Distance between the centerline of the mainshaft and the countershaft is 85 mm
•Fully synchronized forward and reverse gears
•Two-piece aluminum housing with no access plates
•Shift tower mounted shift leaver
•Dodge order code DDC
•Rated for 310 ft-lb of torque (in 1994)
•Weight: 110 pounds, dry
1st 2nd 3rd 4th 5th R
Dodge Ram 1500, Dodge Dakota** 4.01 2.32 1.40 1.00 0.73 3.55
**As of 1994, as per Chrysler tech and press materials. May have been different in later years.
