If the valve tips are not the same height it will put the preload all over the place--typical with a valve job done on a stock head--the exh tips will usually be higher--non mopar shops overlook correcting them--MELLING makes a 030 long pushrod available from any machine shop or many auto part retailers In a stocker it will cure the problem and they are cheap
