I have a 2004 Dakota with a 3.7 V6. Today out of the blue while idling at a stop sign I heard the ding sound that you hear when your check gauges light comes on. I looked at my gauges and the oil pressure gauge showed no pressure. I tapped the gas and it went back to normal.It stayed normal for a while at some red lights then it done it again. I stopped and checked the oil and it was full. I just changed the oil last week end. If there was a serious problem with the motor why would the pressure drop to zero some times when I stop and not do it every time. Could that mean it could be the factory gauge? Has anybody else had this issue? Thanks....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
