I didn't read thru the old thread posted but you torqued it to 40 then if another wrench started to move it at say 45 I'd be OK with that as breakaway torque is gonna be higher but with it turning (earlier) at 35 which is lower than the 40 you left it at then yes I'd want to get some answers. EDIT & the socket etc was all in a straight line especially at the end of the handle arc?
