Originally Posted By Stanton
The FITech recommendation is a 3 - 8 psi pump feeding the surge tank and this will supposedly support 1200 HP (not that I'm anywhere close to that!) Presumably they've done some testing !!!
It's not about how many horses it'll feed, it's about how long it'll feed 'em. IOW, it won't feed 1200 horses for an extended period of time but the capacity of the tank plus the inflow will probably be sufficient for the typical length of time you're producing 1200 HP (quarter mile run, dyno pull)
Yeah, I understand that.
