IMHO, $3500 is way out of line unless you're restoring an engine-less AAR or T/A.
The sleeve wouldn't bother me, but crack inspection and UT are DEFINITELY indicated and should be paid by the seller at that price. Maybe I'm wrong here, if so I want to know what pros think about the value.
Why would you want this block? I'm curious. I mean you could probably buy 10 5.9 Mag blocks for the same amount.
R.
