ruderunner,
Thank you for the reply. I did a search on that site and came up with many threads in relation to that topic. Looks like I've got some reading to do.
I had figured on setting the pinion angle, cutting the housing, and just rotating the ends. However, from what I read on one of the threads, it's better to cut the welds at the housing ends and then rotate the housing ends.
Thanks.
