Originally Posted By 4bbl
I have heard that the front chassis and suspension and rear suspension from a diplomat will bolt up to a same year volare, sway bars and all. true?
76 to 88 should interchange pretty much everything, suspension wise.
Just tore down an 88 Dippy. Most of it looked the same as the dozens of 76-80 F's I've torn down.
As said above, pretty much the same car under the skin with a few subtle differences.
