thought i'd throw this out there.
bought this car a few months ago, only had to time to mess with it a little...things like plug wires, new plugs, new distributor, set timing, fan shroud...you get the idea.
motor is a 360 with magnum heads. supposed to be speed pro 116 flat top pistons. which if zero decked should put the compression around 10.6:1
the car is loud...manifolds, leaking a little, plan to put headers on it.
anyway, did a compression test on two cylinders because that's all i had time for. got to 190psi cold might've gone slightly higher if i kept cranking it. i think it only hit 3 times.
so...the cam. when i put a new distributor in i saw it's a purpleshaft cam.
previous owner mentioned all he could remember was .455 lift.
SO...long story short...does this cam sounds like the mopar p4452761 268/272 cam, 228/231 @.050 ????
https://www.youtube.com/watch?v=0LrDDGx-Sc0
