Per your other post, I've had the same thing happen on more than one neow SB oil pump, the problem is that someone at the factory intsalled a BB oil pump bypass valve with no holes in the sides for the oil to bypass through instead of the SB one with those holes runaway I'm glad you guys caught it before it damage the engine or dnyo thumbs
