how do I know the difference between A, B and E body control arms?????
They are stamped on the arm (I found this out after asking some ID help a while back..) a small couple of letter code on the arm itself will let you know what it's from
From memory it was near the end where the lower ball joint attaches, stamped into the side of the arm itself.
