You know I read the TF article in hot rod magazine about these heads. TF said they wanted to make a head so that we can run the factory valve train BUT now your saying you recommend that we would need to use roller rockers with these heads. So which is it? Am I going to spend another $700 on Roller Rockers just to run these heads?
