Originally Posted By stumpy
Originally Posted By JohnRR
Originally Posted By drce2
its a manual or auto valve body. what kick down would work?its also a cross ram.
What do you mean it's a manual or auto valvebody , it's one or the other, which is it?
and yes I know an automatic valvebody can be shifted manually.
A little educational info for you.
TCI's StreetFighter valve bodies give you better control over your transmission, while improving your car's overall performance. They'll give you the option of either full manual or full automatic control, meaning you can put it in drive and allow the transmission to shift automatically, or shift it yourself manually at any rpm you desire. Great for street and racing use, they come ready for installation and are the same valve bodies installed by TCI in their famous StreetFighter series transmissions.
http://www.tciauto.com/tc/727-904-streetfighterr-valve-bodyhtml/
Oh you mean like your run of the mill VB that Chrysler installed in their transmissions ???
Thanks for the education ...
running up my post count some more .
