This has been an issue since 5 minutes after the first set was sold. As mentioned, the big tool guys have special tools for this, or you can use the various options mentioned. The easiest for you is to go to a good tire shop and have them do it. The 50th set you do is easier than the first. Those guys have already done 50....
