I did the conversion on my Dart /6. I dont wanna screw around with points based on how tight the Dizzy is against the fenderwell.
I didnt use a MP kit I did it piece by piece and it only ran me about $100 in parts. Most parts are readily available at a parts house of your choice.
$40 for the Electronic Dizzy
$20 For the Harness
$2.99 For the Ballast
$30 for the Ignition Control Box
Of course if You can find a junker somewhere,then the parts may be even less.I recently pulled a complete electronic igniton out of an 80 Dodge truck. The guy told me to grab all I want off of it before it went to the crusher. But then again, buying new gives you a warranty.
