I have the Hooker 5101 Super Comps for E-body... uncoated.
If anyone here has that combination maybe they can say, or if you're willing to mock up and correct whatever clearance problems might exist before bolting it together the angle plugs would work.
Other than that, for simplicity's sake the two sets of Hooker headers I've used seem a little more geared towards straight plugs. On the 1 7/8 set two tubes needed modification to work with the angle plugs, on the 2" set they didn't need much of anything. I've never used the part number you have before.
Been told tti's are a slam dunk with either head, but never tried them personally.
Rich H.
Esse Quam Videri
