Originally Posted By GTX MATT
So what is causing that/how do I fix it? Current carb is an annular booser Holley, but Ive had a few carbs on it.
You don't fix it. wink keeping fuel suspended is one of the great challenges of performance engine building. Liquid weighs more than air. Air and fuel moving at high speed... air makes the turn and fuel doesn't. This causes the fuel to enter the chamber atomized and as a liquid. The results clearly seen in your pistons. You might experiment with carb spacers if you have room.
T & K Performance
