These are the results of the test:
1. No constant power (no power at all) pin 30
2. No power when key on (no power at all) pin 87
3. Connection to positive on battery then to pin 85 and I get constant light. Ground is good.
4. Connection to positive on battery then to pin 86 and I get light for about 2 seconds after key release.
30 Common feed
85 Coil ground
86 coil battery
87 normal open
87a normal closed
When I checked #3 my cruise control clicked for about 2 seconds and I heard a faint hum for 2 seconds but I could not figure out where the hum came from.
