Originally Posted By sgcuda
Originally Posted By mopartuner
If a wrench doesn't get pulled into the back of the alternator it means its no good......why?is there any other reason this isn't magnetized?
If it pulls, it means everything is working. If it doesn't, there is a problem, but it doesn't tell you where. Could be alternator, regulator, field wiring or B+. Just a quick Good/No good check.
I never heard of the test of if its magnetic its good.. you
have to energize the field to create the field... I always
use to try a full field test first at the regulator.. if it
works then change the reg.... a vom can test a lot of things
wave
