Pacnorthcuda -
I pulled it out of a 68 sport fury vert.
Owned it for about 4 years maybe a bit longer. Parted out the car and kept the rear because I figured it would cost me way more to buy a sg later.
I know it didn't come with the car. The build sheet didn't show one. Plus the gears are off since the speedo was about 10mph or more off depending on how fast you went.
I will try to remember the tape trick when I pull it out again. Wrapped it up in trash bags and rags to keep the stink down in the garage.
