I have cut the bearings
out without knocking them out... a hack saw blade and
no handle.
How do you reach the 4th bearing with 1/2 of a hacksaw blade ?
How do you keep the metal filings out of the motor ?
If the bearing spun in the bore, it should just about fall out. It may come out stuck to the cam - had that happen !!
