yes, weld a bolt to a 2" wide strip of sheet metal and a piece of 2" angle.
drill 2 holes in the angle piece to bot to frame. bolt goes thru upper cross member.
I had the local metal shop cut the strip. 5$ and 3$ for bolt/angle.
